probably been asked before but my clutch pedal is soft in pressure did bleed it already and it was slightly better but now when you depress the pedal it sticks about two thirds from the top then jumps back also when I tried bleeding it I expected the pedal to rise back up itself whilst the bleed screw was open but it didn`t it stayed hard to the floor and had to be brought back up by hand. The clutch bites well and doesn`t slip so it sounds good but not sure about slave or master cylinders any advice appreciated. eck
