my surf is in the garage getting an uprated head fitted. just went over there and had a look at the old one - was expecting to see cracks between the valves or waterways and valves...but to the naked eye all seems fine. it looks like the head gasket had gone between the cylinder bores
i'm going to get it pressure tested even though i have the uprated one going on - is it possible that someone out there might want to buy an original head from a 70k surf if it passes the pressure test?
also the mechanic spotted the water pump is on its way out, and a hose was split (losing water that way) - got a new one coming today, and the timing was a tooth out (
i've been driving it around like that) causing the valves to hit against one of the pistons which he had to deburr
hoping the timing fix will cure the black smoke and give me a little more performance, and dare i even wish for just a little more fuel economy
and perhaps cure that tap tap tap sound...
other than that, the mechanic reckons everything else is fine
fingers crossed i'll have it back mid afternoon...have a big festival to go to this weekend...
