Hi all,Great site lots of usefull info.
I wondered if anyone has come across this problem before.I have had my 91
2.4 efi surf (auto) for a few month now, and under normal driving its ok,(a
little black smoke on accelaration and intemittent missfire when cruising at
about 50 mph), its when stationary or low range I have a problem.
Idle is normal but when I rev to about 1500 rpm I get bluey white smoke
from the exhaust and a missfire that clears when I increase to aprox 2800 rpm.
Poblems I have found are:Theres a lot of oil in the turbo to thottle body
and play in the turbo.The rubber elbow and hose from air filter are split but taped up,also someone had blanked the two vacuum pipes connected to the
diaphram on the throttle body, not sure what its for but it opens the small
butterfly in the throttle I've put them back but no change.
if anyone has any ideas I'd be greatful as its bugging me now. Thanks
p.s sorry its a bit longwinded
