rough idle
thanks fellas for all your responses, yes did change the pump from an e.f.i surf and it ran exactly the same,rogh idle, the only way it will run smooth on idle is by fitting the non efi pump from the early landcruiser,
SORTED AT LAST after cracking open each injector pipe to locate a cylinder that was down,no3 was very strange, if i undid fully it would miss even worse,tightened down as before,a missfire, but if i loosend the pipe just a tiny bit so a dribble would come out the engine ran perfect, changed no3 injector,bliss you can stand a 50 pence on the cam cover,[nearly] dont always believe you are getting a good set of recon injectors, now looking for a good supplier of injectors if any one knows one.
