1992 surf 2.4 on idle, hot or cold the engine looks and feels like it wants to jump out of the engine bay, the transfer lever shakes uncontrolably,have changed, filters,glow plugs,injectors,injector pump the only thing i havent changed is the engine e.c.u any ideas?
rough idle
Originally posted by terry edgley1992 surf 2.4 on idle, hot or cold the engine looks and feels like it wants to jump out of the engine bay, the transfer lever shakes uncontrolably,have changed, filters,glow plugs,injectors,injector pump the only thing i havent changed is the engine e.c.u any ideas?
Probably an induction or fuel problem. Check for leaks in the air intake system.I used to have a surf me!
May be worth double checking the timing marks on the injector pump. If they are one tooth out, you will get these symptoms.Originally posted by terry edgley1992 surf 2.4 on idle, hot or cold the engine looks and feels like it wants to jump out of the engine bay, the transfer lever shakes uncontrolably,have changed, filters,glow plugs,injectors,injector pump the only thing i havent changed is the engine e.c.u any ideas?Jez
__________________________________________
rough idle
sorry forgot to mention replaced the injector pump with a non e.f.i type from an early landcruiser and it ran fine but wouldnt go into top gear and management lights flashing no rev conter, just been out and swoped the e.c.u but still the same, also worth mentioning if i spray a few squits of easy start into it the tickover will be lovely for about an hour, any more clues lads?JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
Not yet, I think your clutching at strawsOriginally posted by terry edgleychanged the injector pump, exactly the same as before,has anyone had timing marks that are wrong,so to make it run right it has to be a tooth out?
You need to get an working EFI pump back on there. Its probably just getting confused.
