I have a 2.4 Automatic and can only move lever out of park if i press the red button I checked the gearbox level and noticed that it needed topping up so i then topped up to the high level that says hot.
I did this when the engine was running. Tried again to move lever from park -No luck- had to press red button again.
I was not sure that this would make a difference but i also made sure that the small lever was toward the seat as far as it can you go -Still no luck - Any Suggestions.
