hi just joined site just wonderingif anyone else has has had the same prob . iam getting quite a loud noise that appears to be coming from behind the driver side dash the best way to discribe it is it sounds like a trapped bird !!! but its not lol! i drive a ln130 surf it happens when you are moving and stationary thanks any ideas ian
odd noise
Originally posted by clarkeyhi just joined site just wonderingif anyone else has has had the same prob . iam getting quite a loud noise that appears to be coming from behind the driver side dash the best way to discribe it is it sounds like a trapped bird !!! but its not lol! i drive a ln130 surf it happens when you are moving and stationary thanks any ideas ian
Welcome to the nut house, where 'bouts in Devon? susspect we may share a name!Did I mention I have a BLUE one
Tony
speedo cable
I can remember reading somewhere that there was no speedo cable on 2nd gen Surfs, elec cable driven. Is this correct? I only ask because I too have a rubbing noise coming from behind my dash and I had convinced myself it was the speedo cable, until I read the forum post that said it was electrical. Because of this I just left the job and it is still rubbing.
I had a simmilar noise with an erratic speedo needle on an Audi Quattro and all I did was remove the dash, disconnect the speedo cable and pour some 3-in-1 down the cable. Worked fine until I got a new cable.
Let me know if you find out if it is cable driven or not. Cheers.
What would we do without this forum?
