one of my rear seat release thingys that u pull up (the plastic knob), has broken off. Anyone had this problem? there is a screw inside the plastic knob which has broken and that has let it come out. Any suggestions on what to do?
Rear seat release broken
Same problem here too. I have been using long nose pliars and have the blood blisters, from where they have slipped off, to prove it. I keep meaning to take the seat back card off to see how long that metal shaft is. If it is a reasonable length I might be able to bodge it by using any knob form the s****py and join it to the old shaft with a piece of electrical connector block.It's only a hobby!
The knobs thread onto the wire shaft. It's a spiral type self tapping thread for the plastic knobs. I've heard of a few breaking and believe the wire becomes brittle with age and use. Mine are ok but I did attempt to have a look and remove the wire shaft once with the idea of making some spares but this requires removing some of the seat covering as well as the backing to get proper access so I left it alone.
Nev
I've managed to break a small fortunes worth of small knobs getting them to in the end I managed to get a set of ford cortina lock knobs from a breakers and used araldite to hold the buggers in place. So far so good!!Originally posted by NiftyNevThe knobs thread onto the wire shaft. It's a spiral type self tapping thread for the plastic knobs. I've heard of a few breaking and believe the wire becomes brittle with age and use. Mine are ok but I did attempt to have a look and remove the wire shaft once with the idea of making some spares but this requires removing some of the seat covering as well as the backing to get proper access so I left it alone.
Nev
I am the friend of Hypno-Toad
I got some inch diameter nylon rod, turned it down to pretty much the right dimensions and shape as the original, drilled a small hole up the shaft (oo-err misses!), and screwed em on.
This way, I could make sure they were very secure on the spike, and so far, they've been good as gold!!
Might have to see if I've got any rod left, make some more and dish a few out!!!!It just does, OK?
mine operates with a peice of shoelace with a duffle coat button tied to itOriginally posted by DaiZXOne of mine has broken off. All i do is use a screw driver to access the catch from the side of the seat, lift it and bobs you mother's brother, you dont even need the thing on top !!!
I have one knob, which I have to swap over. If you set up in production i'll have a coupleOriginally posted by dave.j.robboI got some inch diameter nylon rod, turned it down to pretty much the right dimensions and shape as the original, drilled a small hole up the shaft (oo-err misses!), and screwed em on.
