hi could anyone with a 2LT engine have a look at this for me, i have a pipe that has been cut and bunged up with a bolt its just to the rear of the fuel pump, have arrowed it on the diagram attached. been trying to find where it should go for a while hope you can help.
2.4 non efi owners help needed
Hi,
I have the non-EFI motor and experience a similar problem with difficult starting when left to stand for a full day or so. I have to really crank the engine to start and I suspect the problem is with the fuel system. I`ll check tomorrow to see if the pipe is blocked.
cheers,
chrisPowered by Toyota!
cheers,
chris
Originally posted by jamsironworkhi could anyone with a 2LT engine have a look at this for me, i have a pipe that has been cut and bunged up with a bolt its just to the rear of the fuel pump, have arrowed it on the diagram attached. been trying to find where it should go for a while hope you can help.
Pipe at the top via rubber piping connected to Injector.
Banjo connection bolts at the back of the Injector Punp & remaining metal pipe is connected via rubber hose which returns to Fuel Tank.
Hope this helps.
There's always a Pay back.... You just can't see it comin !!!!Buncefield Burner
