hi could anyone with a 2LT engine have a look at this for me, i have a pipe that has been cut and bunged up with a bolt its just to the rear of the fuel pump, have arrowed it on the diagram attached. been trying to find where it should go for a while hope you can help.
2.4 non efi owners help needed
Hi,
I have the non-EFI motor and experience a similar problem with difficult starting when left to stand for a full day or so. I have to really crank the engine to start and I suspect the problem is with the fuel system. I`ll check tomorrow to see if the pipe is blocked.
cheers,
chrisPowered by Toyota!
cheers chris i doubt that pipe has anything to do with your starting prob but if you can let me know where yours runs too that would be greatOriginally posted by chrisinflightHi,
cheers,
chris
Just bin out & looked at mine, from your first Pic as already said the return to Tank.Originally posted by jamsironworkhi could anyone with a 2LT engine have a look at this for me, i have a pipe that has been cut and bunged up with a bolt its just to the rear of the fuel pump, have arrowed it on the diagram attached. been trying to find where it should go for a while hope you can help.
Pipe at the top via rubber piping connected to Injector.
Banjo connection bolts at the back of the Injector Punp & remaining metal pipe is connected via rubber hose which returns to Fuel Tank.
Hope this helps.
There's always a Pay back.... You just can't see it comin !!!!Buncefield Burner
