aux belt tensioner
  • aux belt tensioner
    n e 1 know where i can get one of these as mine is noisy. i just want the pully and fixings.....
    CHEERS JOHN................
    bump
      Is that the tensioner from the air con belt? - If so you can have mine!
        Toyota say non repairable. They can be repaired if you are carefull. The bearing can be replaced. I did mine. Remove the pulley. Press out old bearing and retaining plate. Install new bearing. Replace plate and restake. Have a close look and you will see four equally spaced staking points on plate and pulley.Replace plate in same position and restake with a small chisel.
          I should have one, let me have a look later.
            thanks guys.... tony & joe112 let me know how much you would like for it ????
              nothin mate... you can have it... PM oe emal me your adress and i take it off and post it over the weekend joe_thomas@orange.net
                joe112 you are a star, ive sent you contact details by pm
                thanks a lot m8
                  Oops sorry Joe, didn't notice you said you had one.
                    thanks a lot m8
                    Sorry Mate... Been off line for a while for one reason and another... (Very top Secret! LOL)
                    Will post them out to ya in next few days...
                    Its OK Tony... Just don't let it happen again!
