Electric fan sensor switch LN130 K reg
  • Electric fan sensor switch LN130 K reg
    Anyone know the Toyota part number for this switch. I got one from local dealership and it don't look like the original. Much bigger brass bit and a totally different electrical connection. They assure me: "It's The correct one sir"
    Does it look like this....
    http://www.toyotahilux.com/index.php...id=149&vid=948
    If so its OK
    The temp gauge sensor has two versions, and is nearer the back of the stat housing, fan switch is in front of it. Sure the two arn't mixed up?
      [QUOTE=TonyN]Does it look like this....
      Nah, its bigger, see photo. The number on the bag is 89429-35060, it cost £50 and toyota operate a non return policy. They say it's the one for electric fan
      Has anyone else fitted one recently?
        Fan switch
        Fitted one in july last year. Mine was the same as Tony's pic.
        Part No. T89428-20100 £64.18.
          How come Toyota in Luton only charged me £22.00 for the fan switch??
          It's only a hobby!
            Have you got the actual toyota part number and did it look like the one in the photo?
              Mine looked nothing like the one in your photo. It was brass and had a spade connector.
              I have found the reciept and scanned it:
              Whoops! I forgot that nobody can uplad photos at the moment.
              The part No I have is o T83420-20020 WATER TEMP SEND £20.56 Inc VAT.
              What I have could be the wrong part then. The parts guy came out with his digicam, then compared the pic with the EPC diagram and gave me the above.
              It's only a hobby!
