Anyone know the Toyota part number for this switch. I got one from local dealership and it don't look like the original. Much bigger brass bit and a totally different electrical connection. They assure me: "It's The correct one sir"
Electric fan sensor switch LN130 K reg
Does it look like this....
http://www.toyotahilux.com/index.php...id=149&vid=948
If so its OK
The temp gauge sensor has two versions, and is nearer the back of the stat housing, fan switch is in front of it. Sure the two arn't mixed up?4x4toys.co.uk - Keeping you on and off the road...
Mine looked nothing like the one in your photo. It was brass and had a spade connector.
I have found the reciept and scanned it:
Whoops! I forgot that nobody can uplad photos at the moment.
The part No I have is o T83420-20020 WATER TEMP SEND £20.56 Inc VAT.
What I have could be the wrong part then. The parts guy came out with his digicam, then compared the pic with the EPC diagram and gave me the above.Last edited by kitesurf_phil; 13 February 2006, 21:09.It's only a hobby!
