Well, I've been looking at third-hand prices of anything from £40 upwards,
although both you and the last guy, both said £80
so at least I can save up for the summer, when its actually needed
I suppose.
thanks
Bedford 99 pound R12(or whatever the bad gas is out)
and new gas in
if it sounds good to you i will try and get the number
i was looking into getting mine done but the commpressor (insert spell checker here)
does not engage it you press the button (snapped wire at loom)
one of the many things on the things to do list ( a list i will never have time to do so i will prob go to TonyN ((does anyone have a number))
If you want to try doing it yourself, Halfrauds do an R134 regassing kit. Not sure of the price but bound to be cheaper than a professional (sorry Aircondoc).
'all post 1994 vehicles now use an alternative gas, to that of (older cars)
we can give you the name of an approved outfit, who are however able to help' becool 01933 359290
I spoke to him sorry I've forgotten his name and his awkward web-site name
He offered an at home/work installation comprising of an initial test involving another gas, to check for leaks etc, and all being well, a re-charge, which would be more for for a large Toyota
the cost typically breaks down like this,
call out fee £35
gas cost £120
This most likely would be an annual charge,
due to leakage of the modern gas used, in conjunction with a (comparatively)old system likely to lose gas due to seepage and molecular structure
of modern gasses compared to old stuff.
Being mindful of all thing scammy,
and in any way Cash/wallet connected.
I was slightly suprised at cost, and the apparent recurrence on a yearly basis.
after all, I like T shirts and shorts,
and £150 would keep me in hypercolour shirts for a good while,
but he seemed to know his stuff, and I'm thinking about it this weekend,
He did suggest,
holding fire until say April so as to make best of gas, before it might leak out, and cause damage, by trying to run A/C
without adequate coolant-lubricant, which would be a £ot more to sort out
As I understand it,
due to being a 92' (old vehicle) company I contacted initially,
can't or won't touch it as the gas it uses, is not easilly available
So
1; ring around to find someone less scrupulous.
2; grin and bear it, all the time reaching for extra-big chequebook!
3; invest in snazzy looking loose clothing and don sunglasses
all the time anxiously viewing weather reports for that sun
M8 I've never heard the likes of this guy. Shop around and get a second opinion. The leak test is done to make sure the gas is contained longer than a year. Back in RSA aircons run all year long and I never had mine re-gassed in 4 years.
'Gas' problems start to occur when the system is not run for prolonged periods. Like most mechanical systems ie. the 4x4 sytem on road only 4x4's.
i'm pretty sure that my mondeo handbook recommends getting the air con done with the 60,000 mile service!... so that would be 5 years at normal annual mileages!
