Hi all,
Another Newbie with starting problems - Please help me out here as we're just about to get some snow and I'm worried with the drop in temp ,that my truck (1993 ln130 2.4td) will not start over the next few days and I'm going to miss out on all the fun to be had
Just a quick summary of what the problems are:
When i turn the ignition to start the pre-heat circuit on the glowplugs, the pre-heat light just won't go out. I have waited well after the beep however the light still stays on. I have tried switching off and re-trying several times but no joy. My truck was in for a recent service so I had the glowplugs changed out at the same time, however the problem is still there. I have checked the 80amp fuse in the fuse box but that looks okay. What I did notice is that in the fuse box, there is a space marked fuel heater with what looks like a relay connector block but it has nothing fitted. Is something missing from here or should there be nothing fitted as I have glowplugs? Also I can hear the glow plug relay cluncking after about 3 seconds but the dash light still does not go out.
Can anyone give me an idiots guide of what to check for next as I am stumped - also where the glowplug relays are located etc.
I have also added Wynns treatment to clean the injectors just in case these were fouling the plugs.
Many thanks,
Scott.
Many thanks,
Scott.
: . be very suprised if you was given duff plugs though mate.
