Hi guys
Well I decided to use my old Surf while I look for a new shape one & typically it's decided not to play ball!
It overheats in about 6 miles - now it used to be ok but I've had a replacement pump fitted so they're bound to have removed the water hoses.
Initially I thought it could be the thermostat but cheaked that today & it hasn't got one! I'm obviuosly hoping it isn't the HG as it's already had a new head about 18 months ago.
Symptoms are it overheats & blows the water out - heater doesn't get hot & rad fan seems to be on very early, so it would seem to be an air lock??
I've done a search & found plenty of info about it but no instructions as to the procedure to best bleed the system.
Any help would be great thanx
