I've been looking at running on oil for a long time, but never chanced it as if it kills the engine the £1000 to fix it extra means that you won't have saved much in fuel duty.
There's two things that worry me. First is that I have been told vegetable oil has a different flash point to diesel which can screw the timing up or bend sensitive things in the engine over time. Secondly is the glyserine or glyserol in the oil clogs up your injectors, which again will cost lots to replace. Apparently it's not the hardest thing in the world to make bi-diesel by taking the glyserol out of the vegetable oil and then you have the perfect substitute, has anyone got any advice on this, or have I been told a load of nonsence, is veg oil perfectly fine?
