Hello,
Now that the colder weather is coming, the surf is getting very ‘lumpy’ when first started in the morning.
I fitted new glow plugs in the summer, and it has recently had new oil, oil filter and fuel filter. Both batteries have been replaced this February. I have checked the plugs – they are exactly the same as the old ones.
It turns over strongly enough with the starter, but first tick over is rough and smelling of un-burnt diesel. After a few seconds its fine.
Holding the starter engaged for a few seconds helps, as does turning the ignition on a couple of times before starting (seems to give the glow plugs some extra heat).
Any ideas – it was similar to this last winter, I thought the new glow plugs would have sorted this.
Best regards
Andrew
Best regards
Andrew
