I had my friend fit me a new timing belt yesterday. Everything is as its supposed 2 be there. the engine fired up normally like it did before the timing belt change. We changed the fuel filter (which is a FRAM) & primed it. The car took a bit 2 start & started on the 3rd try. Eveverything seemed o.k but when I drove down the road things changed! When I accelerate the turbo kicked in then knocked off as the engine check light kicked in. The truck has no power once that happens & is rough. Today my friend un done all the injectors to let out the air & some came out. When starting the car again it still took a few goes & chucks out a grey smoke when started. It also shows the smoke when accelerating, which it never did befroe.
Any help would be much appeciated! Cheers Tom
Looks like the car is going to have to be striped down again. If one of the cogs has moved how can I know the right postion?
