hi guys/gals thanks for your previous help in this topic
HERE
well i picked the truck up on the 7th sept, all seemed well then a few days later the warning lights would briefly flicker on again, the same lights that illuminated when the pump failed.
coolant level......timing belt......brake......battery
and i noticed little blobs of oil on the drive after parking, i put the oil spots down to remaining oil sat in the sump guard, and the intermittant lights down to a loose wire.
yesterday driving back from Silverstone, the warning lights came on 4 times, each time for a longer period.....
i made it home fine, and thought nothing of it, this morning, soon as the truck was started the lights were on, and didnt extinguish.
i checked the oil, and found it to be low, so this evening i have tried in vain to find out what the hell is going on, the leak isnt obvious, it seems to be driping from the mounting braket for the pump/alternator ,BUT its only drips when the engine is off!!, soon as the engine is started and the area cleaned it stays clean, soon as the engine is stopped it starts leaking again, but only for a short period.
regarding the lights, there still on......
coolant level is fine, the brake obviously is released to drive, and the voltage guage top right of the cluster is reading approx 14v
however after taking the truck for a quick drive this evening(lights on) to try and see what is going on, and finding nothing i returned, i switched of the engine, but it failed to retsrt as the starter was chattering.......low battery voltage??????
what the hell is going on.........please help (a bad 2 months of Hilux ownership)
should the original garage be responsable for at least sorting the remaining oil leak?
HERE
