I have a 1993 Toyota Hilux Surf 2.4 TDEFI 2LTE engine. The cylinder head got roasted and cracked. Bought a reconditioned cylinder head and put it back together. It started perfect and will idle all day long, when I rev it from idle it gives out a puff of black smoke, but then clears. When I take it for a run it gets 200 yards, then black smoke belches from the exhaust and it looses power before cutting out. When trying to start straight after the engine turns over really fast and it wont start. If I leave it for 2mins it starts no problem and will do all of the above again. The only fault code that comes up is 11. I have checked the following:
1. Timing is fine;
2. Injectors have been checked and are fine;
3. EGR valve has been changed and is fine;
4. Turbo has been changed twice and is fine;
5. Crank shaft sensor has been changed and is fine;
6. Timer control valve has been checked and seems to be ok;
7. Vaccum pipes have been checked and are fine;
8. Fuel filter and air filter have been changed;
9. Ball bearing in egr vaccum pipe been tryed
I have ran out of ideas any help would be very much appreciated!!
1. Timing is fine;
