Hiya helpful people. Maybe you can help me again. Had the surf for three weeks now and everything seems to be going ok. Just changed the filters and oil and had a wee oil leak for a few days before i realized i hadnt put a new o-ring on the oil sump plug. That fixed that but now there is another leak!!
It seems to leak for about an hour after using the car and then stops, so not really leaking much fluid at all. The fluid is VERY clear and doesnt smell at all. Not diesel, not engine oil. The gearbox dipstick reveals reddy/brown stuff, and the power steering and brake fluid are light yellow and browny oil. It is warm but not hot to the touch and doesnt feel that oily but it obviously is. as you can see from the pics it is coming down BOTH side of the transmission housing (am i right? dont know too much about cars, yet!) by the oil sump.
It is obviously from a system under pressure as it only leaks when i drive. All the fluid levels are to their perfect levels and dont seem to be dropping at all although i am keeping an eye on them. I also cannot find it from above in the engine bay (ive looked for hours!!)
Hope someone can point me in the right direction. The car is fab, no smoke no overheating, smooth changes, everything works really well.
What the hell is leaking from my car. It is definitely oil, make no mistake about it, it is not water from the air con etc.
If the pics are crap and you want better ones just say and i will go and get better ones.
THANKS GUYS!!!!!!!
THANKS GUYS!!!!!!!
