Recently had a fuel pump leak which was sorted with a Milner leak seal kit.
The motor ran fine before the leak was sorted but now is flat in 1st gear. Pulling away there's basically no immediate increase in revs, just a gradual climb to 2k when it then seems to recover.
When it was in the garage for the repair I know there was a problem starting it when it was all put back together. This appeared to be down to the duel pump position / timing. It was changed and it started.
Is it likely that the pump is in the wrong position?
Cheers,
Rob.
Cheers,
Rob.
