As i have mentioned in previous posts, since a dabble with running on vegoil i have had problems with engine knock/rattle and several people have offered opinions as to the cause from cam problems through to ends. Apart from the knocking, the truck runs fine with no oil or water loss. The only thing i have noticed is a slight misfire/vibratioin at speeds over 65. This week i finally got it listened to by a mechanic who deals with surfs for the local dealer i got the truck from. After much revving and head scratching he informed me there was no real problem and said he was 99% sure the answer was a crappy injector, probably due to the muck from the fuel lines that the vegoil had loosened and a new set of injectors would cure the problem. Does this sound a reasonable diagnosis? As cash is real tight at the moment, i don`t want to lash out on new injectors for nothing. Any feedback from those of you in the know would be most welcome. Also, can anyone recommend the best place for exchange /refurbed injectors, apart from ukcylinderheads, which is the only place i`ve found using the search facility.
Thanks in advance,
Ken.
Thanks in advance,
Ken.
Linda's got Friday reserved in the diary for getting the horse lorry tested and fix Robs truck! so I guess thats it then!!!
