i bought a surf a couple of months ago (k reg 2.4td)and ive been slowly learning bits and bobs that need doing to it and working myself up to them (im real lazy and dont have a huge amount of time) im doing the idler arm bushings in a week or so and lubing up while im on, but i was under the bonnet doing the egr mod and i noticed some black gunge on the engine block where it is screwed down, i have a receipt from the previous owner (who had it from import for a year) saying the pressures had been tested and the head done, wondered if this was a danger sign, should i be thinking of changing the gasket? (the oil is real dirty too looks like an oil change is in order)
i bought dis surf
Could be coming from anywhere, breather pipe, pipe to turbo etc etc. Best bet is to get engine cleaned up then check often to see where it starts coming from.Originally posted by parni bought a surf a couple of months ago (k reg 2.4td)and ive been slowly learning bits and bobs that need doing to it and working myself up to them (im real lazy and dont have a huge amount of time) im doing the idler arm bushings in a week or so and lubing up while im on, but i was under the bonnet doing the egr mod and i noticed some black gunge on the engine block where it is screwed down, i have a receipt from the previous owner (who had it from import for a year) saying the pressures had been tested and the head done, wondered if this was a danger sign, should i be thinking of changing the gasket? (the oil is real dirty too looks like an oil change is in order)Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
I was just reading about this on the ozzie surf site last nite, Dandownunder had this problem and a few others chimed in to say they had similar - oil weeping from the headgasket area down the outside of the block
http://toyotasurf.asn.au/forum/viewt...2+8+conversion
head gasket suspected
thanks for the input guys im gonna clean up and then run it for a bit see if i can see any bubbles or anything (im probably worrying about very little, but its easy to get paranoid when your new to something i think) ill post back when ive cleaned it and had another look.
no hooks! (i have plenty of gracefull Koi in my pond), you personally have an SSR LTD, there is much i can learn from you.
Dont really use the PC much, only since the kids showed me how to get online!
