Since im getting rid of the surf shortly, i thought i'd wind the boost up and see what sort of difference it makes. Put the bleed valve on and took her a run. Stopped wound the bleed valve one full turn + drove again - No difference. Stopped wound the bleed valve two full turns + drove again - still no difference. Stopped wound the bleed valve another full turn (almost full boost) + drove again - no difference in power, however a sensor must have detected over-boost and put the red light on. Got out and wound valve down + noticed oil sprayed around the turbo. Pressure must have damaged the seals. So for anyone who was thinking about experimenting with boost - dont bother it wont make a pick of difference. Did notice a real difference in power tonight however in the frosty air. I get the feeling an intercooler would be a good mod.
Winding up boost pressure.
