It has just stopped again and there is no fuel coming out of the diesel pump. do these go! anywhere near to essex where i can get the Engine management system read, cant find anyone who can repair this type of problem
Help!!
when you say stopped again, loses power and stops ?? or cuts out completly like turning key off ?? your fuel filter been changed lately ?? shut-off solenoid on fuel system working ok ??
do you ever have trouble starting at all ??
how long this been happening ??
warranty ??
check these out and maybe someone can narrow problem down for you
CARL......2.4 T.D,s should carry a government health warning
fuel pump - please help!
Hello everyone
I'm a newbie here
i have some real trouble with my recently bought surf. probs of not starting and cuttting out once or twice - just like you, stevesx.
Took it to Toyota dealer and they diagnosed that it was the celuliod. They ordered the part in but then realised that with this import the celuliod and pump are one and the same. So, new pump!! They have quoted me almost 2000 pounds part and labour!!
Does anybody have any ideas??
First question is, did you buy from a dealer and if so when? If you bought from a dealer, then you have a minimum 3 months warranty. If bought less than 3 months ago, take it back and get the dealer to fix it. If you bought privately then try giving Hilux a pm as he may have a second hand part.Mike G
fuel pump
Thanks for the speedy replies
I did buy from a dealer but he got it on a trade in as he deals in Mitsubishi's.
It isn't on warranty either.
The problem is with the celuliod but the Toyota dealer here in Ipswich ordered a new one but then realised that with this particular Japanese pump the celuliod is part of the pump and not seperate.
I think you'll agree 2 grand is way off the mark! And I only really got it because it was great for shifting equipment to and from church.
for both the above I would start from basics, new fuel filters etc. Might be worth a try and disconnect the EGR on a temp basis to see if it has failed.
£2000 quoted from a dealer who diagnosed a fault then orders the wrong part Hmmmmmmmmmm????????Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
Originally posted by martinkI did buy from a dealer but he got it on a trade in as he deals in Mitsubishi's.
If you bought it from a dealer he has to give you a 3 month warranty irrespective of what cars he normally sells.
Hi allOriginally posted by LeodisIf you bought it from a dealer he has to give you a 3 month warranty irrespective of what cars he normally sells.
Yes Leodis is right the dealer has to give you 3 months warranty?
go and see him tell him that the car was not fit for purpose and you are going to the trade + standards. Have a look on there web site it will tell you every thing there.
Good luck hope it works out 4 you.
Steve.The wheels on my Surf go round and round
spend all of 20 seconds checking your glow plug fuseOriginally posted by martinknot starting and cuttting out once or twice
check the 4 glow plugs themselves, do a search on here and do it yourself
what about air getting in somewhere, check all 4 injectors are tight (2 nuts each - not 1)
change the diesel filter, who can tell when this was last done
check the hose running from the diesel filter to the pump, the jubilee clip at the bottom end may have torn into the hose and air could be getting into the fuel - it happened to me and I had the symptoms you describe
fuel pump prob
thanks for latest suggestions.
Have sent dealer letter by recorded delivery - await his response.
The actual problem is the stop switch on the celunoid which is actually a part of the pump on this model, pump itself is ok, hence my reluctance to pay so much.
martin
Surely a diesel pump reconditioners will be able to strip down your pump and replace the faulty part inside???? give a few a call it could save you some money!!If it aint broke...........give it some more abuse!!!!!!!!
I gave it some abuse.................and it broke!!!!!!!
Never heard of it Cellulose yes
