so i need parts [B]27020-54411 and [/B][B]2930054050 [/B]which are the alternator and vaccum pump assy that fits my 90 surf. im talking to a guy who has a 91 surf with same engine, would this be the same part?
ASAP alternator/vaccum pump assy
[QUOTE=NiftyNev;n1297765]Without searching part numbers I think one may be rear mount vacuum pump and the other front mount vacuum pump. If you post the model and frame numbers for your surf I will check for correct part numbers.[/QUOTE]
the JDM shop im at gave me the part numbers, i am just trying to make sure that my 1990s part is the same as the 1991 part, both 2ltr turbo diesel. so i know the part number just not sure the compatabitly with the 91 which id be getting parts from?
Hey again, so mine is on the back of the alternator, turns out the other guys isn’t, so now I am left without parts available that I can find, not sure where to go this way out?
I think this is what you are looking for. It's all I can find.
[URL="https://www.roughtrax4x4.com/toyota-4x4-parts/service-parts/service-electrical/kuhner-premium-diesel-alternator-55-amp.html"]https://www.roughtrax4x4.com/toyota-...or-55-amp.html[/URL]Last edited by NiftyNev; 3 February 2024, 11:52.
[QUOTE=NiftyNev;n1297794]I think this is what you are looking for. It's all I can find.
[URL="https://www.roughtrax4x4.com/toyota-4x4-parts/service-parts/service-electrical/kuhner-premium-diesel-alternator-55-amp.html"]https://www.roughtrax4x4.com/toyota-...or-55-amp.html[/URL][/QUOTE]
Thanks for your help, looks like it isn’t compatible but I’ll look more into it
