Can anyone please help I bought a 3rd gen auto surf but the 4x4 lights keeps flashing all the time , any thoughts
3rd gen surf 4x4 problem
Originally posted by Big dog View PostYes flashing all the time , makes no difference if button is in or not , still flashes all the time
Unless your truck is stuck in 4wd and can't switch to 2wd and that's why it's flashingYes it's a V8, don't you know I'm loco?
Could be the ADD too.
You can usually feel when its in $WD as you get slight torque steer (or more the sensation of it)
Check that the Vac lines are all intact doing to the ADD unit on the front diff, check that the connectors are all good going to the transfer box.
Do you hear and clicks or clunks when you enable/disable 4wd?
Are the symptoms the same when you try 4WD with the switch and 4WD with the shifter?
Is it multi mode 4WD, (J pattern shifter) or not? (straight pattern on the shifter)More Lift.
More Tyres.
More Engine.
why you useing the stick
why are you putting it into 4l
put it in 2 high and use the button
and drive around a mile or two
and see if it goes out but give it chance
mine takes around couple hundred yards
but if you reving it wont change let it get up to
second or third before you try itthe old git
