Hello all, as I'm finally going to get round to doing the seals (it's only been leaking about 3 years)
I thought I'd find a good write up on it, I tried finding it on the Aus site but it seems to have changed somewhat and I cant find the tech info they used to have,
after a quick look on here it seems I will need to remove the pump completely to do all the seals so if anyone can point me to a good idiots guide I would be very grateful, (or better still come and do it)
I'm just about to order the seal kit from Roughtrax along with oil filter, & timing belt so will I need anything else? (already got a fuel filter), cheer's Ian
Right after reading back a few pages I found the Aus how to posted by Bushwacker (is he still on here?) I use to have all the Aus tech stuff but when my pc was replaced I lost a ton of stuff,
after reading several post on this seal job I'm starting to wonder if I'm up to this job, some say it's fairly easy some say it's a proper bstd, and if it comes to getting it done professionally then I can see me having to get rid, cant afford what these places charge, so for a start I will strip away everything I can so I can actually see the thing and clean it so I can perhaps pinpoint exactly where it's leaking from.
bl00dy veg oil
bl00dy veg oil
