@ scott lee
  • @ scott lee
    Hows it going bud, need to ask a small favour. Are you able to machine a super charger belt idler pulley.???
    www.overfab.uk
    Supercharger - something sounds interesting, always loved the whine of a supercharger
      if its round,and i knew what you where talking about,probably.
      would have to see it first though,most pulleys have a reamed center hole with a key way slot internally,that could be an issue.
      should be over this weekend,have got some bump stops to make for stringer,the new (issue c) BJ spacer drawing and flash drive,and the 8.8 test bolts for the spacers fitted.
      still working on the steering column spacers,haven't been told how long to make them,as yet.
        No keyway mate, just a straight bolt fixing onto a pre bearinged shaft.
        www.overfab.uk
          Yea deffo a very nice sound, and this one yea its very erm different.
          www.overfab.uk
            sounds easy enough..............
            got stringers ridiculous bump stops done today,along with another 5 body lift kits.
            had to squeeze a bit of work in for the company,as well.
            bit of a pain.
            i need my own machine shop
            what time and when are you about this weekend?
            oh,and how big is this pulley? i'll need to bring the right ''measuring stick'' and do a material stock check first thing tomorrow,
              bit of a pain.
              ok i can give you a pulley as a pattern. you won't need a measuring stick, material will need to be ally. I would say the pulley is around 8mm wide and 25mm in diameter, its for a 30cc 2 stroke nitro engine I'm in the process of fitting a super charger.
              www.overfab.uk
                your avin a bubble,mate!!!
                if your going to super charge a two stroke,do a proper one.
                this was my 1978 DT400,i had imported from the states.restored to my usual high spec!
                  Lol I see a trend for the yellow fetish. This engine goes in a 1/5 rc truck. so Its a little bit spesh.
                  www.overfab.uk
                    that does sound very special, I'd love to add a supercharger to my Dodge Charger, need to save some pennies first though, lol
                      okay,i can dig that. so what time are you about?
                        i should be there for 11
                        www.overfab.uk
                          okay,that works for me.
                          looks like its too wet to get under the truck and finish off my chassis work today.
                            well this ''super charger'' is indeed an odd one,mate. as luck would have it, i have the correct size and style insert for the groove on the pulley,result!
                            very odd bearing combination,though.
                            the center bore has a reamed hole of, i think,7.96mm, and the internal bearings are size to size. i would have thought it would have been 8.0mm bang on the money,H7 fit.
                            and OMG have i taken some stick for this!!!
                            got Tuesday and Wednesday off this week,as im taking advantage of the good weather to finish off the underside of the truck, ala popeye style!
                            should get you some turned up Friday afternoon though
                              Lmao mate, im sorry about the stick but you have to see the funny side. There is no real rush on this so if and when mate.
                              www.overfab.uk
