Hows it going bud, need to ask a small favour. Are you able to machine a super charger belt idler pulley.???
@ scott lee
Originally posted by surfenstein View PostHows it going bud, need to ask a small favour. Are you able to machine a super charger belt idler pulley.???
would have to see it first though,most pulleys have a reamed center hole with a key way slot internally,that could be an issue.
should be over this weekend,have got some bump stops to make for stringer,the new (issue c) BJ spacer drawing and flash drive,and the 8.8 test bolts for the spacers fitted.
still working on the steering column spacers,haven't been told how long to make them,as yet.
sounds easy enough..............
got stringers ridiculous bump stops done today,along with another 5 body lift kits.
had to squeeze a bit of work in for the company,as well.
bit of a pain.
i need my own machine shop
what time and when are you about this weekend?
oh,and how big is this pulley? i'll need to bring the right ''measuring stick'' and do a material stock check first thing tomorrow,
bit of a pain.
oh,and how big is this pulley? i'll need to bring the right ''measuring stick'' and do a material stock check first thing tomorrow,www.overfab.uk
well this ''super charger'' is indeed an odd one,mate. as luck would have it, i have the correct size and style insert for the groove on the pulley,result!
very odd bearing combination,though.
the center bore has a reamed hole of, i think,7.96mm, and the internal bearings are size to size. i would have thought it would have been 8.0mm bang on the money,H7 fit.
and OMG have i taken some stick for this!!!
got Tuesday and Wednesday off this week,as im taking advantage of the good weather to finish off the underside of the truck, ala popeye style!
should get you some turned up Friday afternoon though
Originally posted by scott-lee View Postwell this ''super charger'' is indeed an odd one,mate. as luck would have it, i have the correct size and style insert for the groove on the pulley,result!
should get you some turned up Friday afternoon thoughwww.overfab.uk
