Hello wise ones. I have started the gearbox swap, and all I have to do is drop it to get to the last four bolts, but I cant.
I assume you need to remove the bit where the front prop goes into, with the 17mm bolt inside? If so, how? I locked the brakes on by jamming the pedal down, so the wheels didn't turn, but when trying to loosen it, it just sounds like I'm about to knacker the front dif.
So, how do I get that out of the way so I can drop the box to get to the last bolts, and is there a clever way to get the UJs out too? I figured I'd change them all while I had it in the air and the props off, but got the end of one off and that's it....
I'd really like to finish this tomorrow, but if I need anything for the bolt then I'm stuck.
Thanks enormous amounts in advance for tips, suggestions, help, advice.
