Like it says, The truck wont idle, all went fine as useual on the shopping trip and the doctors but as I pulled into the doctors car park she cut out, started it and it immediately cut out again, and that's how it si, I did managed to get the truck home by selecting neutral, starting and revving the engine slightly and when the way was clear jamming it into drive and going, same procedure at every stop and turn, bl00dy nightmare,
Plus ya loose steering when the engine stops and you aint moving
I haven't had a proper look yet but first thought was a vac pipe come off, cant see anything amiss tho at a quick glance, but the engine bay is somewhat, (might be a time to do the IP seals as well,) crowded, so before I make a start on stripping away the gear any ideas?,, she runs fine when your revving,
Cheer's, Ian
Cheer's, Ian
