Originally posted by Dobbslc
View Post
3rd Gen Diff Lock
Okay. Thanks for that. I will source a 20 amp switch as a minimum then. To be on the safe side if anything.
If it's just a solenoid that shunts the diff lock then it won't matter which wire + or - that you switch.
Just make sure it's rated high enough to handle the current. 20amps?
Leave a comment:
Anyone got an idea on this? Am I best to put an inline switch on positive or earth wire between the gear lever and transfer case? Going to have a look at doing it this weekend at some point. Just a basic toggle switch on the dash is all I'm thinking of using. Any further info or ideas would be great.
Leave a comment:
Nothing to do with boggy use. The 3rd gen automatically locks the diff when low ratio is selected. Hence the reason I want to unlock 'just' the diff and leave me still in low ratio. The yards are concrete and hardcored, some of the tracks I tow our water tank (2 ton at least) and mostly a ton of wheat on all day. I want to have low ratio with no locked centre diff for these situations. Alot easier on the car itself and more control at low speed I'd say.Originally posted by MudSurfer View PostHow boggy do your yards get? We use our 3rd gen all over the place on ours, and our Paj, and we have only needed to engage L4 once when moving cattle at the height of the floods when the fields were so boggy we started to struggle with the trailer. Most of the time, with a decent set of ATs on the Surf and MTs on the Paj, they go anywhere in H2 or H4 on tricky bits, I doubt you'd need to do any mods, just use as is and make sure your tyres are up to it.
Leave a comment:
Leave a comment:
Yeah. I will only be using at low speeds and feel it will help with having more control over the car and also save the stress on the transmission when using high ratio as you mentioned. Well worth the effort for me I think.Originally posted by popuptoaster View PostShouldn't harm the truck unless you move more weight than it can handle.
Putting your foot down hard while in high gear puts lots of stress on the crank and gearbox while doing it in a low gear moves that stress out to the drive shafts and axles however a lack of grip normally saves them from damage as you get wheel spin.
Just think of it like riding a bike, you can feel the pain in your legs in to high a gear!
If you have massive grippy tyres or a big trailer on the back you might suffer some damage in low range, but one would assume that you will be taking it easy in those cases.
Leave a comment:
Leave a comment:
Yeah the torque must near double by the feel of it. Ha ha. I want to have the option of unlocking the diff for moving trailers around the farm yard and low speed crawling about when on dirt tracks and diff lock is not needed. Just now I have to do these things in high ratio and low ratio would make it easier on the car at least.
Leave a comment:
Also a rear electronic diff lock was an optional extra.
I actually have the information on my PC somewhere, as part of the transfer box service manual... I'll look it up
What I don't know is how good it is for long term and higher/road speed and prolonged use at that speed, as its really made for low speed crawling.
I'm not sure how the temperatures will go...
I did calculate that on diesel gearing, on 33s, it'll top out in 4th just under 100 on the redline of the V8.... If it doesn't go bang, I'd imagine it'd get there pretty fast!Last edited by Karma Supra; 13 August 2014, 00:29.
Leave a comment:
Yip. Centre diff lock.Originally posted by Sylux View PostDidn't even realise 3rd gens had a diff lock!
Leave a comment:
Thanks for the reply. To be honest I haven't been under and had a look. But if anyone can confirm which plug/wires I need to work on, that would save a bit guess work. A basic inline switch on the dash is my thoughts.
Leave a comment:
I believe so,
It's one of the electric switches activated by the shifter.
I need it isolate which one, but for different reasons...
I'll confirm once I've got around to it, if someone else doesn't beat me!
Leave a comment:
3rd Gen Diff Lock
Can my multi mode 4wd 3rd gen be modified to stop the centre diff locking when low ratio is used? As in, can I fit a switch to control when diff lock is used rather than it automatically engaging. So low ratio can be used on tarmac when towing etc.Tags: None
Leave a comment:
