Heeeeelllllllppp!!!
    Rev counter was fine, but i did noticed that when i was cranking the engine the speedo jumped like i was doing 20miles
      This is like surf CSI, great stuff chaps, hope you solve the case
        Use a paperclip or short piece of wire and jump the E1 and TE1 terminals in the diagnostics box.
        It flashes one every 3 seconds
        Switch on ignition and count the flashes of the red check engine light next to the green turbo light.
        Something else I just thought about, is the RPM sensor on top of the pump. (White plug) If this isn't sending a signal to the ECU the engine won't start.
        Was the rev counter working before the truck stopped?
        Yes it was working
          Yes it was working
          Correct myself, once every 4.9 seconds
            Check/change this part..........
              Ok, thanks, i will. Later on when im back to it.
                I checked. And there is no power reaching to it
                  is there any fuse/relay hidden for power up that?
                  thanks
                  • #24
                    thanks
                    I can't remember, I'll have to check my diagrams.
                    I know it should give out a pulse signal when the engine is turning. If the ECU doesn't receive a signal, the engine won't fire up.
                    • #25
                      just realized,
                      you mean power of the cable, or the sensor you marked on the picture?
                      • #26
                        just realized,
                        The sensor.
                        It may be damaged or broken wire inside the pump.
                        • #27
                          doh! i checked wrong! i checked the cable.
                          i will go down in the morning and check.
                          would you be around on Saturday?
                          • #28
                            Of course.
                            • #29
                              ok changed sensor, 3 different ECU, changed fuses, some relays just in case, and dont start! power where it should be.
                              tomorrow in going to put a 3rd pump i got to see if them 2 are faulty.
                              otherwise im very lost!!
                              • #30
                                A similar problem seems to have been resolved in this thread:
                                http://www.hiluxsurf.co.uk/showthrea...t=45830&page=2
                                I'm sure you've probably seen it...
