Rev counter was fine, but i did noticed that when i was cranking the engine the speedo jumped like i was doing 20miles
Heeeeelllllllppp!!!
Originally posted by BUSHWHACKER View PostUse a paperclip or short piece of wire and jump the E1 and TE1 terminals in the diagnostics box.
It flashes one every 3 seconds
Switch on ignition and count the flashes of the red check engine light next to the green turbo light.
Something else I just thought about, is the RPM sensor on top of the pump. (White plug) If this isn't sending a signal to the ECU the engine won't start.
Was the rev counter working before the truck stopped?the wolf is always bigger when you are scared!!
ok changed sensor, 3 different ECU, changed fuses, some relays just in case, and dont start! power where it should be.
tomorrow in going to put a 3rd pump i got to see if them 2 are faulty.
otherwise im very lost!!the wolf is always bigger when you are scared!!
A similar problem seems to have been resolved in this thread:
http://www.hiluxsurf.co.uk/showthrea...t=45830&page=2
I'm sure you've probably seen it...
