I'm sure I once read on here that when draining ATF from sump, you drain the sump, then you can start engine, go through all gears, then stop engine. This will drain torque converter fluid into sump, allowing you to replace more fluid in one go.
Did I just dream this?? Cant seem to find the post anywhere.
