bugger
went for mot yesterday and failed on the following
measurement
brakes failures: RTB brake imbalance: 12% and 66%
reason for refusal
1) parking brake lever has no reserve travel.
2) offside front brake hose excessively deteriorated.
3) rear ( front to rear pipe. near rear axle ) brake pipe excessively corroded.
4) offside rear ( drop link arm ) anti-roll bar has excessive play in a ball joint.
5) brakes imbalance across an axle.
6) nearside rear brake recording little or no effort.
7) nearside rear rear parking brake recording little or no effort.
i have a friend that's going to do the work for me, says he could get the parts though ALS ( japs 4x4 ) looking at around £105 for parts plus day to sort out. if possible if someone knows whats needed could you advice on the best parts to get and where i would be best buying from. im aware i will probably need a cylinder due to the brake failure, but would at this point be better to get two to keep things balanced ?
any info appreciated
measurement
reason for refusal
