Sorry if this is in the wrong section, but I was hoping to get a quick response as im half way through the job.
I found this thread that tells you how to put a live rear window switch on the inside of the boot >
http://www.yotatech.com/f2/remote-re...button-218926/,
its not a great how to, this is what it says
>>>>>>> If you pull the plastic cover off the lift gate you will see a plastic control box.
There's three wires running from the back of the switch key barrel down to the blue control box.
One white and black one which is the ground. It would be your center post on the switch.
Then there is a dark green with a yellow stripe and dark green with a red stripe. These are your +12v. One is up and one is down. They are located on the blue box. One row in from the passenger side stacked on top of each other.
They go on the momentary part of the switch.
You don't have to have the key on at all. Thats what makes it so slick. It's paralleling the key switch on the outside of the lift gate.
The problem I'm having is that I cant see a control box, and non of the wire colours mentioned seem to exist in my tailgate!
Does anyone have a 'how to' for doing this on a 2nd gen 2.4?
Thanks
Thanks
