Originally posted by tamrat
View Post
yes there is a mix , it's happening in the radiator. The radiator cools the engine, and the lower part of the radiator cools the ATF fluid.They are 2 different , separate chambers. There are a couple of good section pictures on this forum, but can't remember exactly where, or the name of the threads.
As your radiator is possibly damaged or corroded, you are getting the coolant/water and the ATF fluid mixed up, which I fear might eventually destroy the Auto box and disrupt the normal cooling of the engine. So you really need to get the issue sorted, by having a reputable garage replace the radiator with a decent one, new or reconditioned (doesnt have to be a toyota one), and replace the ATF fluid with new fluid.
Then sell the vehicle.
I know exactly what you mean about car prices: we have the same issues here, there is a 120% import duty on each vehicle, which then is compounded by all the other taxes and the other costs (import, registration etc). That's why I suggest you try and invest some money to recover the cost of your original investment.
As for the auto to manual conversion, I have seen a surf done here in Malawi, bit of a bodge really, reverse is difficult to engage as the seat is in the way! I am not a fan , however if dnoe properly it might be worth a try. Auto boxes on jap toyota imports are usually strong , and little ever goes wrong with them, there are rav 4s and corollas here that have been around 10 years and the auto transmission has never had a fluid change, and al is fine.
Dont drive the car while the fluids are mixed up coz I think that'll mess it up even worse.
cheers
fabrizio
