Hello to the good people of this forum,
After what's been like 6 months, the family Surf is finally out of the garage. It was running fine till this afternoon. The reverse gear stopped working (I don't know another way to put this). I tRied to put it back to PARK but made a horrible metal-to-metal grinding noise (the same noise that comes if you don't press the clutch deep enough and try to change gear on a manual transmission veichle). I took out the ATF dipstick and VOILA...the color had changed from the DEXRON II red to light gray. The oil even doesn't feel like an oil. I assumed the oil gotta be changed.
My questions are:
1) Did the oil cause the reverse gear problem? Or is there another cause to this?
2) How do I remove the old oil? I followed the dipstick tube and it lead to a rectangualr box with a single bolt underneath. Is this the correct tanker for the ATF, or should I just use the tube that runs to the radiator?
3) How many liters of ATF can it take in?
Here is a pic of what the oil looks like.
https://www.dropbox.com/s/ml0xq8hpx5...%2007%20PM.png
My questions are:
