So had the Surf a couple of weeks so getting use to it now so just got a few questions on if things are normal
Engine getting up to temperature is tiwce as quick than my old TD5 and the heaters are warm quicker to - anything to worry about ?
Tyre pressures on a 265 75 16 tyre size should be ?
I need to swap my front brake calipers from the standard ones to some rebuilt 2.4 ones. Is everything the same and what parts will I need ?
Also got a small water leak when it rains now and then. Passenger front a pillar trim right at the top gets a drip on it that falls onto the seat bolster - anything common I should be looking at ?
Simple for you chaps but confusing for me lol
