I've just found this online while helping a friend choose a suitable coolant for his Surf...
1. Ethylene Glycol (e.g. Bluecol) - this is the traditional stuff that uses silicates to stop corrosion by passivating the metal surface. This is OK for most European cars, but not Japanese cars.
2. Ethylene Glycol - low silicate. This is required by most Japanese cars. OEM Nissan, Toyota 'red' etc. If you use high silicate AF's in jap cars the water pump seals tend to fail early. I think Merc. and BMW OEM antifreeze is also low-silicate and phosphate-free, but not sure.
3. Mono Propylene Glycol (e.g. Comma Coldstream) - this still uses silicates and is claimed to last 4 years. MPG does not conduct heat as well as EG and currently carries NO recommendation from any car manufacturer - best avoided, esp. for Jap cars. Only claim to fame is that its less toxic than EG.
4. Organo-Acid Technology (OAT) - e.g. GM 'DexCool'. Recyclable and biodegradable; organic based. Claimed life of about 5 years. MUST NOT be mixed with the types listed above - if you wish to switch to OAT type then system must be thoroughly flushed. I would not use this in an engine unless it was the original factory fill - there have been reports that it attacks certain seal materials and solders in some engines. GM (USA) currently having some fun with customers on this one....
5. Ethylene Glycol-based 'Hybrid Organo-Acid Technology' (HOAT). Uses EG, but with OAT-based corrosion inhibitors, most usually BASF's "Glysantin" package (also known as 'G-05'). Lasts 4-5 years (depending on who you believe). I think Halfords 'Advanced Antifreeze' is this stuff. Again, best to flush your system if switching to it.
Is this true? We were about to buy 5L of BP Isocool blue coolant....
