I got my harmonic pulley off this morning to see its cracked and one inner side is sitting 2mm higher than the other!
So I decided to check the crank, need a new woodruff key, its worn the crank a bit where the key has been rattling around, hopefully be okay.
But also, there was a ring on the end of the crank, has lots of holes on it, has cracked right through and was rattling around on the crank.
Does anyone know if this ring is part of the crank or does it come attatched to the new harmonic balancer?
