hi all
if when the gen 3 came out, the older gen 3 ( change over ) had the same running gear has the gen 2, so you would have to treat the 4 wheel drive the same like a gen 2 ( can only use it on soft ground or snow ) can someone tell me if that's right.
also the earlier gen 3 didnt have flared arches. my question is if you was to take the plastic arches off a later gen 3 would it be the same body as the earlier gen 3 ?
