Rear brake sticking on
  • Rear brake sticking on
    What would cause the rear near side brake to stick? I'be had it adjusted before but its done it again.
    The wheel nuts warm up and they then come loose!
    Oh Nana, what's my name?
    Mine was the arm that attached to the axle for the handbrake cable's, it was slightly seized as it didn't return all the way back, so it kept the shoes against the drum which would heat up and start dragging.
      Thanks,
      wd-40 sort it?
        NOOOOO - WD40 is NOT a lubricant !!!
        I'm not familiar with the part in question but I'd suggest dismantling it if possible, cleaning off any crap, removing any corrosion and re-assembling with a light coating of MS2
          Think of it as degreaser and you'll soon stop spraying it over greasy parts.
          In order to prove my point, after fiddling with the oily bits, spray some on your hands and rub together - the grease just breaks down 10X better than swarfeger...
          www.johnthebuilder.info
            Think of it as "magic mist" Tony. Spray loads of it onto anything thats not right, sqeaky hinges, stuck bolts, wet alternators, and if you dont get the results you want, try again till the tin is empty.
            Сви можемо
              and after 6 weeks it'll form a crust of solid varnish - OK on loose fitted parts but no good at all on things with any level of fit ...
                lol
                  If ya can't find any use for it on ya Truck Tony spay it on ya Joints n rub it in If ya have Arthritis
                  11+ Years of Surfs .... n Faultless to a " T " is my Yota
                  Buncefield Burner
                    Way ahead of you, Jess
                    Car is booked in to a mechanic as I'm not going out in the rain.
                    Does anyone in this thread know where, or have wheel studs? I may as well change all 6 since one of them has broke - may be due to the wheel coming loose and banging on the stud.
                      Ya could try ya local stealer Tony mine got me some a couple o' years ago ...
                      Buncefield Burner
                        Thanks will do. Have also asked a question in the main thread to see if anyone has any good ideas. I'd like to replace all six as I really don't know why one has snapped. But all six from roughtrax will be pricey.
                        Thanks again Jess sorry have not replied sooner – have only been back in England a week and have not stopped. I’ll be glad to get back to work – it’s easier!
                          Buncefield Burner
                            Roughtrax it is, then.
                            Local Toyota's wanted all kinds of numbers which I'm unable to get right now.
                            Local motor factors don't stock them
                              Rear wheel cylinder could be partially siezed!
