the earth wire that was causing a problem and the one that is the earth for all the pump sensors is located around the back of the block and goes to the bulkhead above the bellhousing, it's not easy to spot but a corroded earth could be the issue.
My truck would run perfectly and then just die for no reason (you can read it all in the thread)
I had a 3.0 2nd gen auto. Not sure if it's the same on a 2.4 but well worth a look.
The other wires were the coolant sensor and the other sensor wires in pump.
Spark found they were damaged and replaced.
