what is the cheapest way of lifting a surf? and what would you say is best, suspension or body? only looking a 2 inch for now. planning on 33s.
is it best to get the cheap way and fit the bodylift blocks or is suspension a better way? will be off roading from time to time too.
i understand you can do it on the torsion bars and landcruiser spring but what model landcruiser do you need springs from? and are uprated shocks needed? and is it ok do do it 2 inches on the bars?
ta
ta
) you will have enough clearance height with 2 inch suspension but still rub at full steering lock regardless.
