I need some advice on repairing this, as you see it would appear the courier dropped it and it has smashed the bakalite connections box that was bolted to the motor caseing, you can see the two terminals left hanging there with two wires attached to each and i assume the center post which is now badly bent was/is the earth connection, however amongst the smahed bits are another two terminals, ami right in thinking if i can refix the termaials with wires on and then connect the supply to either of these it will run and the direction it turns depends on which way round i connect the live and neutral, (i believe motors can spin in either direction) so what were the other terminals for?
any "best tips for refitting a box to house these terminals? i was thinking of say resin or rubber mold stuff (got a small can of that with the hardener)
the sellers been very good, spent quite some time on the phone to him and he already refunded half the cost, and is going to interlink with these pics to make a claim so i may even have some more refunded,
other than the damage the motor is new (unused), shaft dia and speed (1425)are sopt on for my pillar drill and also it looks right on the old drill,
anyhelp advice much apprecieaded, ta
ment to add as you see the bakalits in so many bits i cant even glue it back together to see how it looked
 that knocke out all power to the garage, always guessed it was other stuff switch'd on as well as the comp that was the prob,
